donmurray Posted June 23, 2006 Report Share Posted June 23, 2006 Anyone know an easy way to remove the paint from a 315 tank? I'm afraid to try any of the usual paint removers on a plastic tank. Quote Link to comment Share on other sites More sharing options...
mostar Posted June 23, 2006 Report Share Posted June 23, 2006 HI THERE IF YOU WANT TO REPAINT THE TANK , I JUST HAD MY TANK REPAINTED BECAUCES IT WAS FADED AND JUST SANDED IT BACK AND REPAINTED THE TANK , I PAINTED IT WHITE TO BE A BIT DIFFERNT , HOPE THIS HELPS CHEERS Quote Link to comment Share on other sites More sharing options...
donmurray Posted June 23, 2006 Author Report Share Posted June 23, 2006 Thanks Mostar, May just try that. I was planning on using the Krylon Fusion paint that's supposed to bond well with plastic, but I'm not sure how it will stick to the orginal paint. May be easier to sand a little and not use the Fusion stuff. What kind of paint did you use? Quote Link to comment Share on other sites More sharing options...
seandellear Posted June 23, 2006 Report Share Posted June 23, 2006 sorry cant help with paint! but just would like to say that mostar ur bike looks tastey nice tank! cheers sean Quote Link to comment Share on other sites More sharing options...
mostar Posted June 24, 2006 Report Share Posted June 24, 2006 HI AGAIN IT WAS JUST A TWO POT PAINT & 4 CLEAR COATS ON TOP , I GOT HELP FROM A CAR PAINT SHOP , HOPE THIS HELPS & GOOD LUCK CHEERS Quote Link to comment Share on other sites More sharing options...
