sy250 Posted June 23, 2006 Report Share Posted June 23, 2006 (edited) Hi there, I am trying to refit the water pump and you have to line up the two pins with the two slots. I have been trying unsuccessfully for the last 2 hours now. As anybody got any tips or advice please. Many thanks Also bike is 2005 250 Pro Edited June 23, 2006 by sy250 Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted June 23, 2006 Report Share Posted June 23, 2006 on the bike, the bit that faces you. use the kickstart to line the slot up with one of the holes, next line the pin on the water pump up to the same hole. Then it should go on really easy. I also tend to smear a tiny bit of grease on there. DO NOT bang it on as it will snap the pin, lined up properly and greased a little it should slide in RELITAVELY!! easy. Hope i helped Quote Link to comment Share on other sites More sharing options...
