scoobie Posted June 29, 2006 Report Share Posted June 29, 2006 Hi, Just bought a 2000 Rev 3 270 which has just had a complete engine rebuild. Should I use synthetic oil for the first couple of hours? If yes which type and at what mixture? I've got Plutline that I use on my KTM, is that OK? After the first couple of hours what oil do you recommend then, and at what mixture? Also what gear box oild does anyone recommend? Finally, what's the torque setting on the gearbox drain bolt? Sorry for all the questions. Cheers, Quote Link to comment Share on other sites More sharing options...
scoobie Posted June 30, 2006 Author Report Share Posted June 30, 2006 Hi, Thanks for the reply. Pardon my ignorance but does 75:1 mean 75ml of oil to 1 litre of fuel, therefore 375ml to 5 litres? Or 1ml of oil for every 75ml of fuel? Cheers, Quote Link to comment Share on other sites More sharing options...
champagne73 Posted June 30, 2006 Report Share Posted June 30, 2006 375mls to 5 ltrs ONLY JOKING 75ml to 5ltrs, I run mine at 70:1 so 70ml to 5 ltrs Quote Link to comment Share on other sites More sharing options...
scoobie Posted July 1, 2006 Author Report Share Posted July 1, 2006 Cheers, Quote Link to comment Share on other sites More sharing options...
