98 Easy Carb Choke
zman92020
Why would Scorpa / Rotax use a carb with the choke knob located on the inside of the bike frame and practically untouchable??
I cant seem to see how are you suppose to get your fingers around the choke pull to lift it up . . has someone figured out some neat trick?? I'm thinking of making a little fork that will reach in over the muffler to lift the choke knob . . Suggestions please . .
zip tip was ok for a temp fix, but I wanted something a little more solid . . I removed the original black plastic knob on the choke lift and machined an new alum one that is 3/4 inch taller, thats 19mm for some of you . . . . now i can get my finger under the top lip and easily like the choke . .
seems like someone would make these as a retrofit kit . . maybe an opportunity here
