zman92020 Posted July 7, 2006 Report Share Posted July 7, 2006 Why would Scorpa / Rotax use a carb with the choke knob located on the inside of the bike frame and practically untouchable?? I cant seem to see how are you suppose to get your fingers around the choke pull to lift it up . . has someone figured out some neat trick?? I'm thinking of making a little fork that will reach in over the muffler to lift the choke knob . . Suggestions please . . Quote Link to comment Share on other sites More sharing options...
mostar Posted July 7, 2006 Report Share Posted July 7, 2006 Hi there I had a 99 easy Put a sip tie around it so you can pull the sip tie up to turn on the choke , Hope this helps Quote Link to comment Share on other sites More sharing options...
ruminski Posted July 8, 2006 Report Share Posted July 8, 2006 I Use a slip tie also, works fine. Have end stick out between muffler and frame, pull to put choke on, and to turn it off slip your finger in and push down on top of choke. works fine. Quote Link to comment Share on other sites More sharing options...
zman92020 Posted July 9, 2006 Author Report Share Posted July 9, 2006 zip tip was ok for a temp fix, but I wanted something a little more solid . . I removed the original black plastic knob on the choke lift and machined an new alum one that is 3/4 inch taller, thats 19mm for some of you . . . . now i can get my finger under the top lip and easily like the choke . . seems like someone would make these as a retrofit kit . . maybe an opportunity here Quote Link to comment Share on other sites More sharing options...
