jack_h Posted July 8, 2006 Report Share Posted July 8, 2006 could anyone here put the routes below into order from easiest to hardest inter novice club man expert Quote Link to comment Share on other sites More sharing options...
montman Posted July 8, 2006 Report Share Posted July 8, 2006 All depends on which part of the country and which club. For instance in South Midland centre Clubman and Novice ride same middle route. Expert and Inter ride same hardest route and In South Eastern centre generally Novice ride 2nd lowest route Clubman are mostly called Sportsman ride that route also and Inters ride their own route and Experts ride the hardest route. How straightforward is that in just 2 Centres? Quote Link to comment Share on other sites More sharing options...
jack_h Posted July 8, 2006 Author Report Share Posted July 8, 2006 im a member of nash mills - so around that area Quote Link to comment Share on other sites More sharing options...
montman Posted July 8, 2006 Report Share Posted July 8, 2006 That is in the South Midland centre - So how does that place you? Quote Link to comment Share on other sites More sharing options...
scorpa3 Posted July 8, 2006 Report Share Posted July 8, 2006 Stratford-Upon-Avon Club routes. A route, Hard: Expert, Inter, Youth A B Route, Moderate: Clubman, Over 40, Youth B C Route, Easy: Novice, Pre-65, Trail, Youth C D Route, Very easy: First timers and Youth D That said, we have some Inters choose to ride the B route and some clubmen ride the A route, so there is no hard and fast rule. In the results it just states Inter B or Clubman A. The trick is to get there early enough to have a look at the sections before signing on. For this year we are also running a Sportsman class on a no award basis. S class riders may swap and choose from any route on any lap in any section. This class is for those who just want to have a ride around and are not bothered about their score. Quote Link to comment Share on other sites More sharing options...
rabie Posted July 8, 2006 Report Share Posted July 8, 2006 as said above it varies dramatically from club to club within a centre and even more across the country South east is generally yellow - wobbler, pre 65 (particularly rigid and sidecar), sidecar, twinshock (sometimes, can be up to blue) youth D red - novice, youth C (and the some to all the above) blue - inter, youth B white - expert, youth A but this is no hard and fast rule. the yellow route isn't at many trials. most are just red, blue and white. some are solo only, changing the nature the the yellow/red route, other expect only modern bikes to enter so will feature different obstacles/route style accordingly class names like clubmen, sportsman, over 50, etc will often appear as well making it very confusing (at best lol!) Quote Link to comment Share on other sites More sharing options...
