rev`er Posted February 22, 2004 Report Share Posted February 22, 2004 I am planning on a 2001 Montesa next month, im planning to get the following things to smarten it up: Keihin Carb. Aktive Reeds, Straight tube for silencer, Hebo Bars, Hebo levers, Seal Protectors, Carbon Fork Guards, Talon Sprockets, Iris chain Can you guys think of anything else i should get?? Quote Link to comment Share on other sites More sharing options...
hrc2002 Posted February 22, 2004 Report Share Posted February 22, 2004 Hey Rev, Hebo Bars? Is it worth it? The bars wont improve the bike, I personally dont think its worth it. Quote Link to comment Share on other sites More sharing options...
beta boy Posted February 22, 2004 Report Share Posted February 22, 2004 get a $h!t load of anodised bolts and put them allover your bike they look great got them on my bike Quote Link to comment Share on other sites More sharing options...
monty-python Posted February 23, 2004 Report Share Posted February 23, 2004 Go for the jitsie kevlar fork guards, they are thick and the quality is great. The carb, reeeds and straight tube sound like a good idea, but do you really need the rest. Why not save yourself some money and just replace the levers, bars, chain and sprockets when the originals wear out/ break! Quote Link to comment Share on other sites More sharing options...
subira Posted February 23, 2004 Report Share Posted February 23, 2004 You'll probably need to do the Clutch plates and Gear Oil. So keep Quote Link to comment Share on other sites More sharing options...
rev`er Posted February 23, 2004 Author Report Share Posted February 23, 2004 Ill probably just get the reeds, carb and straight tube then, what do you mean by a real handful, will it be really torquey, and pull of my arms, will the boyesen reeds not sharpen up the bottom end, and so does the keihin carb, i thought that the carb to sharpen up the bottom and tha active rreds to sharpen up top??? Cheers Chris Quote Link to comment Share on other sites More sharing options...
subira Posted February 24, 2004 Report Share Posted February 24, 2004 I'd try the straight tube first, with standard carb and reeds. Personally I'd then fit Boyesens with the standard carb. Makes for a strong bottom end and and will rev out with plenty of power. The Haven porting would be next as it is spot on, didn't Wonder Boy get his motor done ? There's no doubt that the Keihin and Active's will make a very powerful motor. But if its pulling your arms off it might be a bit more difficult to ride Its not all about power, I had a 280 conversion and it was very hard to ride, even a couple of local Experts preferred their 'stock' 315s to it. Ask the Sandiford Montesa riders (Boyd or jrsunt) what carbs/reeds they use ? Quote Link to comment Share on other sites More sharing options...
montman Posted February 26, 2004 Report Share Posted February 26, 2004 Hi Guys Can you tell me what effect the straight exhaust tube has? Quote Link to comment Share on other sites More sharing options...
