powellriver315 Posted July 15, 2006 Report Share Posted July 15, 2006 thanks for your thoughts on my dragging clutch issue, swapping it with aftermarket cr plates sounds like the best idea. my local dealer is asking for the exact year of cr 250 or a part number. my 315 is a 98, i'm guessing the cr is also but they changed around that time. any help would be great. Quote Link to comment Share on other sites More sharing options...
montesa315 Posted July 15, 2006 Report Share Posted July 15, 2006 i,v got a feeling that the cr clutch never changed. its the same one for the 250 as the 500. if you just get clutch plates fromm a 98 cr then it should be fine Quote Link to comment Share on other sites More sharing options...
ssiegmund Posted July 15, 2006 Report Share Posted July 15, 2006 Apperantly there are a couple different compounds of fiber plates and the lighter tan paper style are the ones that perform best. Quote Link to comment Share on other sites More sharing options...
koevoet Posted July 16, 2006 Report Share Posted July 16, 2006 After speaking to the importers in the UK this week about my own 315 clutch,dont get the friction plates for the CR as the they are all the same compound,the Mont friction plates are paper and cork,making them more progressive than the instant snatch of the motocrosser ones. Quote Link to comment Share on other sites More sharing options...
powellriver315 Posted July 16, 2006 Author Report Share Posted July 16, 2006 thanks for the info, i guess i'll get the steele plates only and try that for now. Quote Link to comment Share on other sites More sharing options...
koevoet Posted July 19, 2006 Report Share Posted July 19, 2006 I just finished putting my clutch back together.I had a big problem with drag,the bike leaping forward when put in gear when cold and also occasionally the bike continuing to drive when the clutch pulled in. I just fitted a set of 6 raceline dimpled steel plates and a new set of STANDARD Montesa friction plates.4 cork and 3 paper.starting with a cork then the 3 paper then the remaining cork,as in the manual.The bike is now sweet,with a progressive clutch and zero drag.It previously had a set of 7 cork plates such as would be found in the CR 250 crosser to give instant delivery hence the snatch that I experienced.My bike is totally transformed,it's 'kin ace.try it. Quote Link to comment Share on other sites More sharing options...
