stefan Posted February 22, 2004 Report Share Posted February 22, 2004 When removing the skid plate on my '01 I found that the shape is changed a wee bit ( seems that the pre-owner did quite a lot of work on rocks...) Questions: When mounting an OK skid plate, would you have a non-contact between lower engine housing and skid-plate? What is the measured distance for bolt hole to bolt hole (rear to front) on a new skid plate? The 10 ton press needs a bit of a workout Stefan Quote Link to comment Share on other sites More sharing options...
landrover Posted February 23, 2004 Report Share Posted February 23, 2004 on a ok skidplate there is a piece of rubber which touches the bottom of the engine when we have had the bashplate off we put the two front bolts in first screw in only a couple of threads then you can juggle the bashplate about to put the two back bolts in then tighten them up Quote Link to comment Share on other sites More sharing options...
stefan Posted February 23, 2004 Author Report Share Posted February 23, 2004 So the skid plate bends over the lower engine housing? Does that mean that there is no need to use my 10 ton press? Cheers, Stefan Quote Link to comment Share on other sites More sharing options...
jaylael Posted February 24, 2004 Report Share Posted February 24, 2004 Only if the rear bolts won't reach their holes without the use of force. Normally there is a slight preload on the rubber with the skid plate bolts all tight. Quote Link to comment Share on other sites More sharing options...
