Clutch Fibre Plates
dr nick
I had a tip from Dan Clarke on a training day, to rub my clutch fibre plates with scotchbrite to clean them and to buff the metal plates up if they are shiney.To stop the clutch drag problem I`ve got
I`ve never taken the clutch plates off before and have no idea what new ones look like,so I`m not sure if mine are worn or not.The actual fibre is about 0.015"-0.020" thickness (approx)either side of the plate
BTW...its a 98 Techno
Any help appreciated
Regards
N
it is simple exactly the same as on my techno take the clutch cover off with the bike on its side undo the six bolts and take the other cover off the friction plates are the ones with the little pads on them and the other ones are smooth just clean them up and buff them and bolt together done ust change the gear box oil just remeber DO NOT pull the clutch lever in while the springs are off or you wont get the clutch to work properly again without bleeding it
