Repsol Replica
nickerlias
well from the pictures of the 06 test in tmx the repsol replica was the old
05, you could tell by the stickers on it.
dont konw if there will be an 06 repsol due out soon
if you don't want to buy a Mitani clutch pack, there is a cheaper way. In the clutch pack there are four paper friction plates. replace those with four cork plates, the same as the outer plates in the pack. the clutch gets a little bit snappier but much better if you ask me. you could also replace the steel plates with jitsie's which makes the clutch smoother but without the drag.
Edited by Ludde
