Brake Pads
dale
Hi,during the trial today,i noticed my brakes did,nt have the same bite as usual.I dont think i got any grease/WD40 on rotors or pads,so was wondering if the pads/rotors have glazed up?Iwas going to sand the pads and put a bit of heat [blow lamp] on the rotors.Any advice greatly appreciated.Thanks :blink:
Try cleaning the rotors and pads with an arisol "brake cleaner" from the auto supply! Wipe the rotors clean with it on a rag or towel! Sand the pads lightly!
It will disburse any most any oily matter that may be the problem.
Then get them good and hot and splash with water!
Good luck! :blink:
Edited by copemech
Just done what was suggested,plus heated up the pads with blowlamp and they caught light :blink: so must of been contaminated with something flammable :o .Anyway it worked a treat -Now how do you do a stoppie? :o
